LS-7 Question
Old May 25, 2007 | 06:49 PM
copperheadmv's Avatar
Default LS-7 Question
Is it posible to put a 427 LS-7 into a 1994 Camaro Z-28 originaly equiped with a LT-1? Anything would be helpful, Tips or coments.
Old May 25, 2007 | 07:34 PM
nickdotcom's Avatar
Default RE: LS-7 Question
anything is possible with enough money and skill
Old May 25, 2007 | 08:18 PM
well im getin the motor and trany for about $600. Im a student at a tech school, studying auto mechanics. and my buddy is a welder. so i can do most of it all myself to save money. I just need to know if space or anything not obvious will give me any trouble.
Old May 26, 2007 | 12:18 AM
95slvrZ28's Avatar
It's all the same frame, you will however need different mounts. You will also have to switch out almost all the sensors and the actual computer system...have fun[:'(]
Old May 26, 2007 | 02:35 PM
JD1969's Avatar
You might need a tubular K memeber because of the fittings in the oil pan for the dry sump. But how in the hell are you getting an LS7 and trans for $600? Somthing is fishy....
Old May 26, 2007 | 03:23 PM
No, its all ligit. I'm friends with a salvage yard and they resently got a covette that was hit in the rear. So I'm getin the motor and transreal cheap.
Old May 26, 2007 | 08:02 PM
JD1969's Avatar
Well if ever run into another one I'll give you double that, maybe more.
Old May 29, 2007 | 05:49 PM
LT1RUNNER's Avatar
Good luck with the swap!! Pics are a must!!!!! Some people have all the luck.
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
