Low oil pressure
Old Feb 20, 2008 | 04:22 PM
Spartan66's Avatar
Default RE: Low oil pressure
ok what i was saying was you know how the rings distribute oil to the cylinder walls and what not, well i was thinkin if its simply that they are struggling distributing the oil/ER and it will pass once the ER is done filling in the cylinder walls. I will do an oil change this weekend unless i see a difference but i just want to make sure im not going to drain out all the oil like 2000 miles before i have to since id have to get a new filter and all the oil all over again and that doesnt sound to appealing to me because im trying to save money for my CAI.
Old Feb 20, 2008 | 05:26 PM
MassholeLT1's Avatar
ORIGINAL: importmd
what? just drain it if you think its causing an issue.
+1 Spartan for the 2nd time- DRAIN THAT **** OUT OF YOUR CAR!!!! It is HORRIBLE for your engine....
It's mainingredient isPTFE, commonly known as the Duponttrademark: Teflon. These product have tiny particles of the stuff, or "flakes" in the additive, literally a solid suspended in a liquid. Whilethese products may have some short term benifits in quietedengine parts etc,most have been found to do long term damage to your engine.Some literallyeven tell you to shake the product on the back of the can. This solid can clog up your filters, and oil passageways in lifters and other areas of the engine.They do much more harm than they could everdo good, just change your oil every 3k and use a quality filter and that is the best thing you can do for your engine.
READ:
Snake Oil!:Is That Additive Really A Negative?
Article and Photos by Fred Rau
ROAD RIDER/August 1992/Pg 15
Information for this article was compiled from reports and studies by the University of Nevada Desert Research Center, DuPont Chemical Company, Avco Lycoming (aircraft engine manufacturers), North Dakota State University, Briggs and Stratton (engine manufacturers), the University of Utah Engineering Experiment Station, California State Polytechnic College and the National Aeronautics and Space Administration's Lewis Research Center.
Road Rider does not claim to have all the answers. Nor do we care to presume to tell you what to do. We have simply tried to provide you with all the information we were able to dredge up on this subject, in hopes it will help you in making your own, informed decision.
You Can't Tell The Players Without A Program
On starting this project, we set out to find as many different oil additives as we could buy. That turned out to be a mistake. There were simply too many avail able! At the very first auto parts store we visited, there were over two dozen different brand names available. By the end of the day, we had identified over 40 different oil additives for sale and realized we needed to rethink our strategy.
First of all, we found that if we checked the fine print on the packages, quite a number of the additives came from the same manufacturer. Also, we began to notice that the additives could be separated into basic "groups" that seemed to carry approximately the same ingredients and the same promises.
In the end, we divided our additives into four basic groups and purchased at least three brands from three different manufacturers for each group. We defined our four groups this way:
1.) Products that seemed to be nothing more than regular 50-rated engine oil (including standard additives) with PTFE (Teflon TM) added.
2.) Products that seemed to be nothing more than regular 50-rated engine oil (including standard additives) with zinc dialkyldithiophosphate added.
3.) Products containing (as near as we could determine) much the same additives as are already found in most major brands of engine oil, though in different quantities and combinations.
4.) Products made up primarily of solvents and/or detergents.
There may be some differences in chemical makeup within groups, but that is impossible to tell since the additive manufacturers refuse to list the specific ingredients of their products. We will discuss each group individually.
The PTFE Mystery
Currently, the most common and popular oil additives on the market are those that contain PTFE powders suspended in a regular, over-the-counter type, 50-rated petroleum or synthetic engine oil. PTFE is the common abbreviation used for Polytetrafloeraethylene, more commonly known by the trade name "Teflon," which is a registered trademark of the DuPont Chemical Corporation. Among those oil additives we have
Old Feb 20, 2008 | 05:31 PM
ORIGINAL: Spartan66
FYI Spartanthis why manypeople herethink you couldnt wrench your way out of awetpaper bag- "I cant afford to change my oil 'cause im saving for a Cold Air Intake"....
Old Feb 20, 2008 | 06:37 PM
Spartan66's Avatar
i CAN afford to do an oil change but it takes away from my financial "cushion" i dont make ALOT of money so spending it needs to be well planned out because i have bills to pay too. Ive got some coupons for shucks and mobil 1 and a fram filter, ill go buy that and swap it out this weekend...
Old Feb 20, 2008 | 07:30 PM
thats what I like to hear- it just doesnt look right when you want to do performance mods over basic maintainence- get that Engine Restore out of your engine and get a fresh filter on there.....
Old Feb 20, 2008 | 07:37 PM
SpecterGT260's Avatar
Ninja Administrator
no kidding. change ur oil and put fresh synthetic in it. and the ticking is an exhaust leak most likely
Old Feb 20, 2008 | 08:48 PM
importmd's Avatar
+1 for m*******. if 20 bucks hurts your finacial cushion maybe you shouldnt be spending your hard earned money on your car.
Old Feb 20, 2008 | 09:13 PM
ORIGINAL: Spartan66
Rings have nothing to do with oil pressure, and they do not distribute oil to the cylinder walls.The spinning crankshaft slings oil to the cylinder walls and lubricates them.The job of the oil rings is to wipe excessive oil off the cylinder walls, and the job of the compression rings is to provide a seal between the piston and cylinder.
Old Feb 21, 2008 | 04:32 AM
Spartan66's Avatar
yeah thats what i ment, when it squeegies it... but never mind that theory im just going to drain it. 20 bucks doesnt hurt my finances it just pushes me close to being broke lol.. right now ive got 174 in the bank, next pay check will be 360 on friday so that will be a prime time to do it. As for the ticking i know i have an exhaust leak (where the cat would be its just a gap with a small pipe thats poorly welded holding them "together". Idk if my exhuast manifolds have a leak but im pretty damn sure its coming from the engine.. if i had a camera idrecord itand post it.
royco95
Aug 2, 2015 10:25 AM
BoricuaHec01
LS Series Tech
Mar 17, 2011 05:56 PM
angelus
Feb 20, 2010 01:17 PM
divineal
Oct 23, 2009 12:21 PM
IBSTROKIN
Sep 9, 2009 10:40 PM
