Looking for Aluminum Driveshaft
Old Jun 27, 2010 | 04:04 PM
MaxTheKiing's Avatar
Default Looking for Aluminum Driveshaft
About to go out next weekend and look for an Aluminum Drive shaft for my 1997 3.8
I heard that any type from 93 to 02 will fit, but which years have the 1 piece alum ones?
Old Jun 27, 2010 | 10:27 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
You can usually dig them up for around $120 or so. I have one I might be interested in selling
Old Jun 27, 2010 | 11:49 PM
libertyforall1776's Avatar
Don't ya want a newfangled carbon fiber one? ;-)
http://www.acpt.com/article4.html
Old Jun 28, 2010 | 09:19 AM
This might be a dumb question but does the driveshaft go in the rear or the front
Old Jun 28, 2010 | 09:23 AM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
The driveshaft goes between the rear of the transmission and the center of the rear end. Its what transfers the power from the transmission to your rear to turn the wheels.
Old Jun 28, 2010 | 09:28 AM
Is there a How-to or write-up anywhere telling/showing how to remove and install these?
Old Jun 28, 2010 | 09:34 AM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
Its quite simple actually. Jack up the rear of the car after chocking the front wheels. Jack it up so both wheels are off the ground. Pull the ebrake and climb under the car after making sure its secure. At at the rear end there is a yoke with two straps holding the Universal joint to the rear. Remove the bolts you can reach. Then have a helper take the ebrake off and spin the rear tire until you can reach the second set of bolts. Pull the ebrake again and remove the other two bolts. Place a prybar or large screwdriver between the yoke and universal and pry it towards the front of the car, keeping one hand on the shaft. The shaft will slide further into the transmission and come free from the yoke. Then pull it back and its out. A small amount of trans fluid may come out.
Old Jun 28, 2010 | 01:31 PM
thetal1's Avatar
carbon fiber sounds pretty cool IMO
Old Jun 28, 2010 | 03:06 PM
Vandee's Avatar
u missed that if your removing the two piece it you will have to unbolt the carrier bearing from the car as well.
Old Jun 28, 2010 | 03:30 PM
Yeah, hopefully i can find a 1piece though.
libertyforall1776
Oct 11, 2011 03:38 PM
Mikey.
Sep 13, 2011 11:39 PM
8485Chevycowboy
Apr 30, 2008 02:17 AM
chevy_man
Mar 13, 2008 07:35 AM
The Banks
Mar 7, 2008 04:15 PM
