longtubes, mids, or shorties is the question
Old Mar 2, 2009 | 12:46 AM
Ridealldayz28's Avatar
Default longtubes, mids, or shorties is the question
Hey my fellow camaro owners, i recently purchased a 94 z28 and man what a fun ride. i cannot decide what headers to install although i want to be able to put them in myself and i hear longtubes are a b**** because you have to lift the engine. so what do u think guys?
Old Mar 2, 2009 | 01:15 AM
Spartan66's Avatar
Longtubes would be the best use of your money. Your stock manifolds are just good as anything else. Not sure if you have to lift the engine, but i wouldnt doubt it. Im sure its been done without lifting it though.
Old Mar 2, 2009 | 02:59 AM
thanks man, i have heard you can gain about 20-25rwhp from longtubes, do you know if that is accurate man?
Old Mar 2, 2009 | 08:57 AM
whammer3024's Avatar
ROTM Winner
your stock manifolds are worth crap vs. any header. depending on your state's emissions, long tubes are definitely the best choice, more so for the low end torque over mids or shorties. and yes, 20-25 rwhp is accurate for longtubes
Old Mar 2, 2009 | 02:20 PM
robmnrd's Avatar
You don't need to lift the engine, but it makes it a hell of a lot easier.
One thing to remember, is that if you can sacrifice the time and pain to get those longtubes in now, you'll have better access to those spark plugs for the rest of the time you own the car. That's true for mids/shorties also, but the gains you see performance-wise from longtubes make the aches worth it.
Old Mar 2, 2009 | 08:00 PM
Talking
thanks alot guys, does anyone know about how many hours the install should take?
Old Mar 2, 2009 | 09:49 PM
95slvrZ28's Avatar
If you're experienced with cars and have a friend to do it you should be able to get it done in a weekend. Of course, this is providing you can get the old system out without any headaches. When I did my header install that took up 1/2 of my time because I twisted off half of the bolts in the Y-pipe. You'll need a good penetrating oil and a buddy will be a big help (probably one with small hands if you're a big guy) to get into those tight places. Also remember to get some O2 extensions if you're not soldering savvy and you can't make your own.
Old Mar 3, 2009 | 08:08 PM
o2 extensions?, thats for the o2 sensor right? do you need longer ones then stock, also there is two of them right?
Old Mar 3, 2009 | 09:41 PM
95slvrZ28's Avatar
Yes, yes and yes.
Failed Devices
LS Series Tech
Sep 5, 2010 12:06 AM
Camaro Man 1999
Feb 11, 2008 12:37 AM
BadBowtieZ28
Jun 11, 2007 04:23 PM
z28scorpio
Mar 25, 2007 02:09 PM
