Intake Baffle??
Old Mar 10, 2009 | 07:51 AM
camaromanv6's Avatar
Question Intake Baffle??
Hey, I was reading on this site about a baffle inside my intake to reduce noise. now i may soud kinda dumb askin this but thats what this site is for right? Is the baffle in the throttle body itself? i couldnt see anything in the routing to the air filter. and 2, if it is in the throttle body could i take it out and it would sound better or would that jeapordize the performanc of the car itself?
Old Mar 10, 2009 | 04:33 PM
95slvrZ28's Avatar
It's not a baffle, they're referring to the resonator (commonly referred to as the "Donkey Dong"). It's a hollow tube that has a calculated length and diameter to produce a certain tone. This tone then produces destructive interference with common intake noises, thus making the noise seem less apparent. You're not going to get any performance by removing it, so I wouldn't worry about it.
Old Mar 10, 2009 | 05:12 PM
95slvrZ28's Avatar
"would removing the resonator make it sound any better? where is it exactly?"
Better is a matter of opinion, so to you, I don't know. It's going to increase the sound that an intake makes, if you like that sound you can get a new intake elbow, but you can't remove the resonator unless you plug the whole. Personally I wouldn't want a home-made plug job that may go bad sitting at the entrance to my motor. The resonator is located on the bottom of the intake elbow that curves from your air filter/box into the throttle body.
Old Mar 10, 2009 | 05:31 PM
yeah thats true. thanks for your help man. i got some pics uploaded. not the best cause they were off of my phone. comment though. by the way yours is pretty bad..i wish i had an LT1
crimson09
Dec 15, 2018 07:07 AM
carid
Vendor Special Buys
Jan 20, 2015 07:08 AM
tuletymeZ28
LS Series Tech
Aug 22, 2010 12:12 PM
z28rob18
Jun 22, 2009 04:40 PM
