Ignition issue...Is this supposed to be here ?
Old Sep 8, 2012 | 04:03 PM
  #41
phoenix901223's Avatar
Originally Posted by Greg08
exactly bro. i just swapped to the same opti as well. did u make sure to artic silver 5 your icm ? and i install new copper plugs on the z28 as well, they are good. Also, i got some 7mm wires from rockauto.com idk if 8mm are better for performance, i just didnt want to run into fitment problems
No, i never removed my ICM from its mounting bracket. I should probably do that since i notice a slight loss of power after warm up....In the next few weeks I will probably swap plugs and wires, starting with wires.
Old Sep 9, 2012 | 12:24 AM
  #42
sounds like the computer is seeing some bad numbers from one of the sensors when it goes into closed loop. how old are the 02 sesors? have injectors ever been cleaned and tested?
Old Sep 9, 2012 | 10:37 PM
  #43
Greg08's Avatar
Old Sep 10, 2012 | 10:46 AM
  #44
02s are brand new. injectors never cleaned or tested. Where would i get them tested?
Old Sep 10, 2012 | 11:23 AM
  #45
Greg08's Avatar
there are places all around
Old Sep 11, 2012 | 11:49 AM
  #46
do a search for injector shops in your area. i use a place called doctor injector. heres a national business FUEL INJECTOR CONNECTION - Shop Home
81Anna
Dec 31, 2014 09:46 AM
jml2002
Jun 19, 2013 07:47 AM
Cam396aro69
Jun 25, 2009 04:44 PM
RallySport88
82-92 V8 Tech
Jul 15, 2008 05:31 PM
azneau28
Jun 14, 2007 06:10 PM
