Idiot lights
If you are low trac is on, that means there is a problem with speed sensor on your wheels. The computer isnt reading the sensor properly. Or it could be the wheel speed harness is damaged
I just started having this exact issue today after I cleaned out my TB with TB cleaner, then it randomly stopped, but when I turn my car off and back on they flash for a few seconds then turn off. Went to AutoZone had it scanned, nothing abnormal. I took a look at the schematic turns out Low Trac, ABS, and Brake lights are clustered together...
http://shbox.com/1/ABS_schematic.jpg
I think getting the IAC sensor wet with the TB cleaner must have done something, when it started to dry off it started running better, and lights went off.
Edit: Also, correct me if I'm wrong, but after the car is running the battery shouldn't be an issue since the alternator is going.
I fixed my lights and here's how. Check the ground near the power steering fluid bottle. There a nut on that then some wires, and then another larger nut with a big wire underneath, that was loose on mine, tightened it and everything is good now. Hope this helps.
That same nut was loss tightened it up now heres another problem the battery seems to drain down if not run in a couple of days. I put the battery charger on so we'll see if that fixed the idiot lights.
