Question on Proform Valve Covers
Old Jul 13, 2008 | 09:06 PM
94z's Avatar
94z
Default Question on Proform Valve Covers
I bought some 1.6rr and im not sure if they will fit under my stock valve covers and im wondering if I woukd have to do anything (and if so what?) to these to make them fit in my car
http://store.summitracing.com/partde...p;autoview=sku
Thanks in advance for any help
Old Jul 14, 2008 | 12:58 AM
95slvrZ28's Avatar
Default RE: Question on Proform Valve Covers
Those aren't going to work so well for you...it's pretty hard to find a good set of LT1 valve covers. The passenger side valve cover has to be "dented" on the front to accomodate for the alternator. So you either have to take a hammer and dent them yourself or relocate your alternator to get an aftermarket set of valve covers on. You should be able to fit those 1.6 RR's under your stock valve covers if you cut 1/2 the interior braces off.
From Golen Engine Services:
Old Jul 14, 2008 | 01:11 PM
viciouZ's Avatar
You can machine the ribs down on the stock covers, which will usually work. Otherwise, I'd recommend the Canton aluminum covers.
viperffx
Oct 11, 2010 09:57 PM
rockstarbass1
82-92 V6 Tech
Nov 2, 2009 10:23 PM
alilaw
Oct 16, 2008 06:57 AM
carguylt1
Nov 7, 2006 05:38 PM
69camaro1
Oct 11, 2006 02:15 PM
