i have a problem with my exhaust system on my 2000 camaro shaking
Old Oct 16, 2015 | 04:00 PM
ajsumney's Avatar
Default i have a problem with my exhaust system on my 2000 camaro shaking
hi I have a 2000 Camaro with the 3.8l v6 and my exhaust shakes while idleing and driving the support member for the exhaust looks like there may be some type of support or bracket that goes in between the pipe and the support member can anybody help answer this question I would greatly thank you
Old Oct 17, 2015 | 11:27 AM
First make sure that the engine is idling smoothly. If it idles rough, then the shaking of the engines will cause the exhaust to shake. If the engine is shaking, misfire or bad engine mounts are usually the cause and you need to address ithem before messing with the exhaust.There should be some sort of flexible joint between the exhaust manifold and the exhaust pipes to keep normal engine motion from transferring to the exhaust pipes. If the exhaust was worked on, there is a good possibility that the flex joint was done away and the exhaust system put back together as a solid unit. This is a common practice of cut rate exhaust shops avoiding the cost and work involved in doing a proper job. If the engine idles properly, and the exhaust system put together properly, they you should make sure the proper hanger placement and isolating mounts are used.
98stuntin
Nov 22, 2011 12:23 AM
CCj
Nov 3, 2011 03:47 PM
superman
82-92 V6 Tech
May 1, 2011 11:29 PM
Albyint
May 14, 2010 07:14 PM
95Z6speed
Mar 10, 2009 04:44 PM
