How to remove fuel injectors?
Just going over my user manual... Is there another way to evacuate the fuel system pressure without a gauge? Like pulling the fuel pump relay and running the car until it doesn't start?
It looks like I just have to evcuate the fuel pressure, remove the bolts holding the fuel rail and the fuel injector clips.
Before I get into it, would anyone with experience like to give me some input on this?
Im switching my fuel injectors around to find a misfire.
Thanks!
Thanks!
just remove the 4 nuts and use a flat head and twist a little on each injector. pry one up a little.. move to other side do the same just be carefull the rail bends easy. replace both the upper and lower o rings. use fresh oil around o ring when reinstalling. releasing pressure not as big as deal as people make it out to be.
i unhook the fuel lines and remove the rack with the injectors still on, then remove injectors. less chance of dropping something in the injector holes. right away plug them holes with paper towel or something. woh this is a ls1,,, nevermind, not sure how they come off.
