how to install a light bulb into a 94 camaro drivers door
Photo(s) please? ![Wink](https://camaroforums.com/forum/images/smilies/wink.gif)
I have decided to use the stock bulb and lay it across the back of the swithplate and mount it myself. Even the LEDs aren't that bright thru that tiny hole. I checked my 2002 N.H.R.A. Formula door which has the same hole, and it is the same set up as the camaro, only the bulbs are red. And since I don't know if its an LED or just a stock red bulb, in my Z28, I mounted the bulb across the back of the switch plate and then installed the switch plate. Now the entire switch plate lights up well.
