Hestation, Loss of Power, Slow shifting
Old Sep 2, 2008 | 03:06 PM
02CamaroV6's Avatar
Default Hestation, Loss of Power, Slow shifting
Have a 2002 Camaro, 58,000 miles, V6, automatic, T-top, 35 Anivarsary with electronic throttle body. Car hesitates on acelleration, slow in shifting (sometimes must let up on accelerator), looses power. No trouble codes except P0420 [ drop in efficiency on muffler bank 1]. Scanned data while operating seems okay. Have installed new plugs and wires. Replaced (1) injector. Injector system cleaned. replace fuel filter. Fuel pressure hold steady... increases slightly on acceleration on road test. Replaced (1) ignition coil...all three tested resistance wise to be okay. Cleaned ignition module mounting base and new heat-transfering grease. New MAF. Tested MAP with new2 replacement, it is okay. Cleaned throttle body. Visual check of lines did not reveal a leak. Blocked EGR valve with no effect.
HELP!!!!!!!!!!!!!!!!!
Old Sep 2, 2008 | 03:18 PM
02StanGT's Avatar
Default RE: Hestation, Loss of Power, Slow shifting
Possibly the catalytic converter is partially plugged.
Old Sep 3, 2008 | 02:05 AM
noz's Avatar
noz
hey you might wanna check any loose grounds ....trust me.
josh H.
Jun 21, 2015 12:06 PM
djordan
Mar 25, 2012 10:32 AM
80z28guy
70-81 V8 Tech
Jan 4, 2010 10:51 AM
gemlam
Feb 26, 2009 08:37 AM
LT1RUNNER
Dec 4, 2007 10:45 AM
