Here are some pics of My 94 Z28 LT1 engine rebuild
Old Jul 21, 2010 | 11:19 PM
kool. when did you do this?
Old Jul 22, 2010 | 11:20 AM
1BADA$$RS's Avatar
looks great man
Old Jul 22, 2010 | 12:51 PM
automotive_solutions's Avatar
nice....
Old Jul 22, 2010 | 09:34 PM
CNCman's Avatar
1augapfel, thats nice to here you were able to do that ! It is hard to scrounge up the cash. Just finished rebuilding the front end too, bushings, spindles, tires ect. Craby, the project was between April and Sept 2009. Still have door window motors, heater core, headliner, gotta a burnt spark plug wire too, yet to fix. I had to save up for over a year before starting. THANKS and good luck all !!
PS: that 3.4 is plenty of engine, the LT1 is a little more than needed, can get you in trouble on rainny days.
Old Jul 22, 2010 | 10:16 PM
Stix80's Avatar
pretty sure you could get in trouble on any day
Old Jul 23, 2010 | 02:00 AM
1BADA$$RS's Avatar
dude ive heard about the only way to pull those motors is drop it with e sub frame from under the car. that bracket could make a killing
Old Jul 23, 2010 | 07:29 PM
CNCman's Avatar
i will try to post the dimensions, you could use 3/4 plate steel, and cut it out with a torch, drill a few holes...shackles and eye-bolts, done. The bellhousing bolts were hard to reach, top ones from the top ( intake was removed ) and the rest from the bottom. I didn't like the idea of being under the car on a bottm removal, so decided make it a top pull.
Old Jul 23, 2010 | 07:45 PM
1BADA$$RS's Avatar
yeah but if you could make a bunch of them then patented it you would make loads of money man atleast i think so i did a bottom drop on a sebring IT WAS A P.I.A the way we did it was pull the fenders off jacked the car up on blocks unbolted the sub frame and exaughst then lowered it back onto the ground unbloted the shock towers and misc bs then there was a body brace we hooked our motor lift to the brace and lifted the body up and blocked it up again then wraped a chain around the front end and got the wieght off of the wheels and rolled it out im going to post pics soon
Old Jul 29, 2010 | 10:03 PM
obzeetj's Avatar
I am with you 1augapfel. I re built my 3.4 and it was a chore well worth the lessons learned. I admire the LT1 to the max and I know that I can relate to all the sweat that CNCMan went through. Love the innovative technique of pulling the engine out from under the windshield. I will have to make one for my next build.
CNCman
Jul 18, 2010 03:55 PM
ultra94z
Jan 2, 2009 09:05 AM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
Ryanp81
Sep 22, 2006 11:27 PM
fenderboy
Apr 30, 2006 07:51 PM
