Heater in 95Z28
Old 10-12-2017 | 12:24 PM
pcarollo's Avatar
Default Heater in 95Z28
The heater in my 95 Z28 (118k) has a bit of an issue. It works but doesn't get near as warm as it used to before the head gaskets were fixed last Jan. When I'm driving in the morning it's just not that warm and sometimes I'll get better heat when driving in the city vs. the freeway. The temp rises to about 185 as normal, sometimes even hotter, but the heat just doesn't get as warm as it should.
Think this could be a thermostat problem? The car doesn't have a leak and I haven't had any issues with overheating.
Thanks
Old 10-12-2017 | 01:05 PM
the heater core could be plugged or the flow regulator may have something stuck in it. the return heater hose has a regulator in it that limits the flow so the engine can warm faster and heater core works better. its basicly a disk with a hole in it that only lets a little coolant through. be a good idea to back flush that heater hose and flush or replace heater core.
Old 10-12-2017 | 10:39 PM
also make sure your getting the door slam when you turn up heat. should hear a thump when you move heat dial from cool to warm and warm to cool.
Old 11-08-2017 | 04:39 PM
pcarollo's Avatar
Any tips on flushing the heater core?
Old 11-08-2017 | 10:57 PM
i have heard guys using garden hose and light pressure, not running water very open. core is built to handle low pressure, like 5 maybe 10 lbs pressure. home garden hose can have some pretty good pressure 50lbs. would need to remove both heater hoses and tap into it. be best to unhook hose with restrictor at the heater core.
noz
VS
21
12-01-2008 07:20 PM
Bigsexy5.7
10-01-2008 12:46 AM
reesez28racer
VS
04-05-2008 09:37 AM
reesez28racer
VS
32
04-04-2008 02:40 PM
maxxiepad
04-16-2007 03:48 AM
Quick Reply: Heater in 95Z28
