Headers for a Camaro?
Old Jun 3, 2011 | 04:33 AM
fuhhuayt's Avatar
Default Headers for a Camaro?
So i'm trying to find a good set of Headers for my 1997 Z28 Camaro, i'm looking for some that will help me get some more power in the low end, but i also need some that will last me a very long time....so any links or prices would be good, i don't have alot of specifics, only ones are: i'm looking for some under 500$ and ones that won't crack...thanks
Old Jun 3, 2011 | 07:59 AM
Phalen123's Avatar
Herron performance, pacesetter longtubes with y pipe 399.99, coated 599.99 <- I think
Old Jun 3, 2011 | 09:46 PM
Roachz28's Avatar
im getting pacesetter and ypipe through texas speed. you can get both for under your budget. u also should do spark plugs as well.
Old Jun 5, 2011 | 01:57 PM
libertyforall1776's Avatar
^ Motor mounts too if you're up near 80k mi.+ or so...
Old Jun 5, 2011 | 08:19 PM
Phalen123's Avatar
And where is the best place to get these motor mounts?
Old Jun 5, 2011 | 10:05 PM
Myself I'm going to stick with factory, but some do solids or poly -- depends how much vibration you can handle The benefit is supposed to be reduction in motor twisting... UMI has solids, Spohn has some, and others... For poly, Prothane or Energy -- you just mount the bushing in the stock clamshell...
Old Jun 5, 2011 | 11:00 PM
Phalen123's Avatar
Well I hate vibration and its not like I'm racing so I think ill do stock as well
Old Jun 11, 2011 | 09:46 AM
greatac's Avatar
Fuhhuayt - - before you spam this board with yet another topic that has been more than covered here, please take a moment to think about your click-through strategy. Do you really think that someone who enjoys turning a wrench on their car is likely to say "I saw an ad on CamaroForums and I think I'm going to download Rosetta Stone and learn to speak French...as soon as I finish this oil change."
At least use the same year and type of Camaro when you spam so you are less obvious to regular readers. When you actually buy a Camaro and work on it, you will find a lot of good advice here. In the meantime, good luck with those click-throughs.
KSCAMARO
Feb 25, 2015 05:44 AM
RFxCamaro
Nov 19, 2010 08:04 PM
gozzy341
May 18, 2007 09:21 PM
chev
Dec 17, 2005 07:32 PM
