Head Gasket might be going
Old Mar 12, 2011 | 04:38 PM
Phalen123's Avatar
Default Head Gasket might be going
I think one of my head gaskets might be going
i have white smoke from the exhaust during start-up and though and its pretty warm out now
its only during start up and when it heats it up its not as noticeable but its still there
so basically, how hard is it to change head gaskets in these cars and while im in there what are some moderately cheap performance modifications i could apply
Old Mar 12, 2011 | 04:45 PM
3800camaro's Avatar
What engine is it? They aren't that hard depend on engine depends on how long it will take.
Old Mar 12, 2011 | 05:21 PM
Massey's Avatar
the white smoke that goes away once the engine has warmed up some is perfectly normal. It is from water condensing in the exhaust as it cools. Temps outside dont matter as much as humidity levels do. You need to worry if the smoke is all the time and the exhaust smells like burnt antifreeze.
Massey
Old Mar 12, 2011 | 08:30 PM
Phalen123's Avatar
its a 93 LT1
and theres allllooottt of smoke though
and could this also be trans fluid?
i read soemthin about it somewhere and my trans leaks badly
Old Mar 13, 2011 | 01:49 AM
Massey's Avatar
If the trans leaks then you would see bluish smoke and it would not come out the tail pipe. How about you make a vid of the engine running cold and warm and lets compair that will help. You can also do a chemical exhaust gas test (I cant post the vid here the Army blocked youtube again).
Massey
Old Mar 13, 2011 | 11:36 AM
are you losing coolant?
Old Mar 14, 2011 | 12:10 AM
RFxCamaro's Avatar
When its earned up and no .longer smokes on startup rev it up, if it smokes then yes its a headgasket, or at least very likely. Compression test is the best way to tell.
Old Mar 14, 2011 | 05:54 PM
Phalen123's Avatar
that compression test is gonna be scary, that engine hasnt had the gaskets changed since 1993
i hate deterioration with a passion
hyflyr
Feb 21, 2012 08:26 PM
keaboi
Aug 26, 2011 08:01 PM
99 camaro T-Top
Oct 6, 2010 09:51 PM
ryden
Mar 14, 2010 05:30 PM
dcanada53
Mar 5, 2008 06:01 PM
