Hazard light help
Old Sep 1, 2011 | 12:08 PM
iLL95's Avatar
I Like to Party
Super Member
Exclamation Hazard light help
So When i bought my 95 Camaro some of the material covering was missing off the steering column on the top(this where the hazard light button was?) and there are just some exposed wiring etc. One night I was leaving my GF's house and noticed a screw not screwed in all the way on the side of the column. My first thought was 'Ok this could be a problem' so I took out my drill and drilled it back in but in doing so my hazards came on and wont stop even with the car off(I then undrilled the screw)..hazards still on... I resorted to pulling the Hazard Unit from the bottom of the knew bolster but now my blinkers wont work(which I need to pass inspection). Did I trip a wire or something when I drilled the screw in? I need some help :/
Old Sep 2, 2011 | 10:49 AM
sure sounds like that screw was the flasher switch. can you post a couple pictures.
Old Sep 2, 2011 | 01:09 PM
iLL95's Avatar
I Like to Party
Super Member
This is how far the screw was sticking out.
I then screwed it in and the hazards came on.
I resorted to taking the hazard unit out but now the blinkers cant work.
Old Sep 2, 2011 | 01:10 PM
iLL95's Avatar
I Like to Party
Super Member
Oh and if someone can give me a tip on how to fix the column or where to buy a new one from please let me know. Dont see why the guy before me tore up the steering wheel..bastard.
Old Sep 2, 2011 | 02:16 PM
buck658's Avatar
he probably put the screw there where the hazard switch was so that he could still use his hazards. try acting like the screw is the actual button and press or pull it but not too hard and see if it turns them off. if it was me just seeing how torn up it is, id just replace the whole column. its not that hard to do just a few brackets and some wires
Old Sep 2, 2011 | 03:45 PM
iLL95's Avatar
I Like to Party
Super Member
Tried the press down method and it didnt work, I might just have to get a new column and have someone look at the wiring..
Old Sep 2, 2011 | 04:03 PM
gota pull out to turn off flashers.
Size:  49.2 KB Name:  PB070008.jpg
Old Sep 2, 2011 | 04:46 PM
iLL95's Avatar
I Like to Party
Super Member
dope.thanks bruh for going through the trouble
Socom
Nov 9, 2013 01:41 PM
Pro78z28
Jul 24, 2013 03:58 AM
yannj
Jun 19, 2013 09:42 AM
og556
LS Series Tech
Sep 21, 2006 01:51 AM
