Grinds when shifting into reverse
Old 08-23-2007, 03:16 PM
Default RE: Grinds when shifting into reverse
ORIGINAL: squisher
ORIGINAL: z28pete
You need to replace the reverse gear synchro.
Reverse is NOT synchronized. If you stop and then hold the clutch about 5 seconds before shifting it also prevents it from grinding.
The T56 (6 spd on V8s) tranny has a syncro'd reverse, but the T5 (v6 manual) does not. So if there is any movement in the gearbox while trying to shift into reverse, it will grind.
My bad, I had a V8 car in mind.
Old 08-23-2007, 03:53 PM
Iceman1023d's Avatar
so there's nothin i can do about it?
Old 08-23-2007, 11:06 PM
meteoralp45's Avatar
not worth spending the money, why spend 100s of dollars when all u gotta do is shift into 1st...id rather do that lol
Bandit 43
05-19-2011 10:42 PM
Chaotic94
06-19-2010 02:02 PM
corinnemarie22
03-30-2010 12:02 PM
herestolife1000
05-31-2008 06:07 AM
Gordon24Camaro
01-19-2008 02:45 PM
Quick Reply: Grinds when shifting into reverse
