Gasoline Fumes/Fuel Pump Issues. Please Help!
For the gauge level, only thing I can think of is since you used "the hatch method", possibly you weren't able to remove the sending unit/pump assembly as gently as you need to. Regardless, you must have tweaked the float arm for the gauge reading to now be thrown off.
A few weeks ago I took the pump back out to see if maybe I got the seal in wrong. It looked okay. Only thing I saw that was out of place is there were a few crumb size pebbles under the seal. I assume that ruined the seal? Should I replace it with a new seal again and see what happens?
lol. Take the cover off before you fill the tank next time. Then take a looky see after you get to your next destination.
Hint: if it's dark out, use a flashlight to see, not a lighter.
