fuel rail
Old Feb 20, 2013 | 05:00 PM
Patrick Quentin Musick's Avatar
Default fuel rail
just a quick question i pulled my fuel rail had two cracked injectors now im putting stuff back together n im fighting the injectors to go in the ports any suggestions or advice its a 94 3.4l v6 auto
Old Feb 20, 2013 | 05:49 PM
Assuming you only replaced the two injectors, hopefully you replaced them with OEM style instead of cheapo aftermarket ones, to prevent a mis-matched fuel flow between them and the other 4 with a resulting rough running engine and the SES light popping on. Go ahead, ask why I mention that, but you probably know the answer!
Is it also safe to assume that you replaced ALL the o-rings with new ones? You want to give them a coat of oil, but they'll still be a snug fit going in.
Old Feb 20, 2013 | 06:16 PM
agree, not a good idea to change injectors without having them flow tested to make sure they are flowing the same. make sure the intake holes are clean, it can take a bit of pushing and wiggling to get em to pop in when the o rings are cold.
Old Feb 20, 2013 | 09:52 PM
i replaced all of them at once just to be safe
Old Feb 20, 2013 | 10:19 PM
Attaboy! Did you get em all slid in ok?
Old Feb 20, 2013 | 11:03 PM
i have them connected to the fuel rail but im struggling with getting in the ports it doesnt help that the high today was 32
Old Feb 20, 2013 | 11:10 PM
No, cold doesn't help much at all. Warming up the o-rings with a hair dryer might help.
Old Feb 23, 2013 | 05:42 PM
someone said that i should bolt the fuel rail to the plenum n try to install it that way opinions?
Old Feb 23, 2013 | 07:15 PM
are you sure you got the right o rings? should not be to hard to get em in there. i dont think the bolts are long enough to reach till they get in so far.
juice+
Jun 9, 2012 10:51 PM
michaels3241
82-92 V6 Tech
May 18, 2011 02:20 AM
mrfreez
Jan 21, 2011 11:58 PM
doww301
Jun 15, 2010 05:11 PM
