Fuel Pump
Old Feb 22, 2008 | 07:16 PM
importmd's Avatar
Default Fuel Pump
Hey, i cut the trap door in my car, pulled the pump, now im ready to order a new one. Is anyone running a aftermarker pump? Want to know what you guys would recommend for a aftermarket replacement, does a walbro 255 flow enough? thanks
Old Feb 22, 2008 | 08:49 PM
02StanGT's Avatar
Default RE: Fuel Pump
I hear alot of people recommend the Walbro. It will flow enough for alot of horsepower.
Old Feb 23, 2008 | 06:32 PM
importmd's Avatar
No one has upgraded their fuel pump?
Old Sep 16, 2009 | 09:03 PM
ZZZZZ YA's Avatar
I'm personally planning on running a twin pump setup from www.lonniesperformance.com I've heard some good things. I am running a 383 with a V1 SC Pro charger though. Not sure what your pressure requirments are. Hey do you have and pics or the specs on where to cut the trap door I need to do this and dont want to hack up my car buy guessing where to cut.
Old Sep 21, 2009 | 12:40 PM
bob50's Avatar
I just did the replacement over the weekend for my Son. With a very limited budget my Son purchased his pump off Ebay for $48 delivered (Felco products?)
Using the trap door method was easy, but cutting open the plastic pump housing and sealing it back up was a little tough.
Car runs perfect now.
Link http://www.taekwondoplus.org/z28/fuelpump.html
Good luck,
Bob
Old Sep 21, 2009 | 01:09 PM
z28rob18's Avatar
a walbro 255 will support up to 600hp. i put one in on my build ill be pushin the limits with the spray so i may build a dedicated.
jon_uscg2001
Aug 25, 2011 12:23 AM
nehidustin
Jun 28, 2010 07:30 PM
carmodder
82-92 V8 Tech
Jun 23, 2008 12:50 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
