Figured out my problem!
Old Dec 18, 2007 | 04:38 PM
1994z28's Avatar
Default Figured out my problem!
I finally figured out my hard starting problem on my 94z.
I took off the MSD pro billitopti(spline shaft, that the previous owner installed)today and the ball bearing on the rear of the distributor is shot... little metal shavings all on the lowerof theback of the distributor caked with oil that was most likely leaking from the distributor sealand the shaft is all wobbly.
Is there anything mechanical with theenginethat could have caused this failure or is it most likely just a bad bearing?
I didnt think ball bearings were idealfor high speed applications...???
Massey
Sep 17, 2010 01:39 AM
black95z28
Apr 15, 2009 10:40 PM
MusicMan
32
Dec 14, 2008 08:21 AM
jimidude87
82-92 V8 Tech
Apr 16, 2008 07:41 PM
