Exhaust Tips
Old Aug 15, 2012 | 10:45 PM
2Z's's Avatar
Default Exhaust Tips
Are the rectangle tips on my 93 Z28 slip fit or do they need to be cut off if I want to replace them? I see a clamp on both sides which is making them look like a slip fit.
Old Aug 16, 2012 | 07:42 AM
jkeaton's Avatar
Have you loosened the clamps and tried to remove them? Most I've seen you can loosen the bolts and slide them off, unless a previous owner had them welded on, which should be pretty easy to tell. If you do remove them, I would be interested in taking them off your hands for you....
Old Aug 16, 2012 | 07:59 AM
Edwardgp's Avatar
That's your slip fit.
Old Aug 16, 2012 | 08:07 AM
2Z's's Avatar
Im thinking of putting a set of chrome ones on from a 2002 Trans Am . The ones from the T/A are straight and not offset though. Do you think it would still look ok?
Old Aug 16, 2012 | 08:11 AM
Edwardgp's Avatar
You could put them on and find out. You could also send yours out to get triple show chrome plated. Yours set out for chrome would last a lot longer. Much better material used at the U.S.A. plants.
Old Aug 16, 2012 | 01:10 PM
greenarrow's Avatar
September 2009 ROTM
No, they will be noticalby offset. I tired that as well at one time. If you're set on doing it, I would suggest going to a muffler shop and just getting a whole new performance muffler put on, should only run around $150 for muffler and all.
Old Aug 16, 2012 | 06:26 PM
Edwardgp's Avatar
What about having yours chromed?
Old Aug 16, 2012 | 06:31 PM
2Z's's Avatar
Probably wont spend the money on getting mine chromed,,, not worth it when I can very easily buy a set.
pondo1000
Oct 17, 2011 11:36 AM
Nismo91
2010+ V6 Tech
Jan 20, 2011 08:07 PM
famlyguy18
May 6, 2009 05:26 PM
3.4CamaroCDOG
Feb 26, 2008 09:56 PM
Celticsfan
Jul 26, 2006 02:05 AM
