exhaust question
Old Sep 20, 2010 | 01:01 AM
timmyz28's Avatar
Default exhaust question
96 lt1 camaro, it has bbk shortie headers, hi flows, and glasspacks (yes i do have glasspacks cus im a cheap bastard). it is true dual. well lately i have been noticing when i drive, it is loud but it also has like a crappy hollow sound to it and i think its the glasspacks. i was thinking about running just the headers and hi flows and choppin off the glasspacks. just want some opinions and/or ideas
Old Sep 20, 2010 | 01:10 AM
most ive seen that have done that have put mufflers back on.
Old Sep 20, 2010 | 06:43 AM
torque_is_good's Avatar
loud is nice for grabbing attention but after a while, open exhaust grates on you. It's fine at the track or for mucking around but not constant driving.
Old Sep 20, 2010 | 09:48 AM
timmyz28's Avatar
yeah i know what you mean about the loudness. i wanna eventually put loudmouth mufflers on but i mean for now, should i cut em off? it doesnt sound right, like its loud but weird.
Old Sep 20, 2010 | 11:35 AM
Massey's Avatar
another thing you are going to have to worry about if you run open exhaust or glasspacks for that matter is burning the exhaust valves. A tuned muffler like the Flowmaster 40 series provides a good sound but leaves enough back pressure to cool the exhaust valve enough to keep it from getting burnt. The cooling of the exhaust valve also assists in the scavenging effect which helps the new exhaust gasses escape from the cylinder. Be careful running open exhaust, you need to have your engine built to do it, and the factory does not give you the proper parts to make that happen.
Massey
Old Sep 20, 2010 | 01:57 PM
timmyz28's Avatar
will slp loudmouth give me the proper back pressure then? or are they also too open as well?
Old Sep 20, 2010 | 02:25 PM
Massey's Avatar
No the SLP exhaust will give the proper backpressure, it actually maximises the scavenging abilities of the stock manifolds and gives a good sound. The muffler in the loudmouth works very similar to the Flowmaster, in that it muffles the sound by using the sound pressure against itself. almost no restriction, just enough to keep the engine safe.
Massey
jax 73
Mar 21, 2010 02:30 PM
DKap22
Mar 22, 2007 10:43 PM
bill12690
Mar 19, 2007 03:29 AM
NomadicZ28
Jun 9, 2006 03:00 PM
Jester
Jan 10, 2006 03:12 PM
