Exhaust
Old 02-11-2011, 10:11 PM
sebi1990's Avatar
i didnt buy the system it was on the car when i got it its basically just a duel outlet muffler and 3 inch cat back pipes then i cut the cat out and welded in a piece of straight pipe
noise inside the car wasnt to bad but you could deff hear it and it will always rasp out mine did at about 3500 rpm
ok thanks. 3.5k RPMs is pretty high
Old 02-11-2011, 10:12 PM
sebi1990's Avatar
Originally Posted by Buffalo02Z28
Any exhaust system that you get will add power. The stock V6 exhaust is very restrictive.
Why is it so restrictive and is there any way you can make it not as restrictive as it is? What would be the way to go about it?
Old 02-11-2011, 10:14 PM
sebi1990's Avatar
and youll deff want headers a nice cat back with stock manifolds is useless when it comes to power youll also want to hook up the intake system you need to breath is as good as you can exhale
Did you buy extra headers for your car or were they already installed? Did you feel a noticeable difference after putting them on? Was the sound louder/quieter?
Old 02-11-2011, 10:37 PM
Chaotic94's Avatar
September 2011 ROTM
True Duals FTW!!! Borla Mufflers in this vid being revved up to 6000rpm's!!!
http://www.youtube.com/watch?v=4YfZ2Msn2Ig
Old 02-11-2011, 10:39 PM
Buffalo02Z28's Avatar
True duals with long tube headers will give you the best power gains.
Old 02-11-2011, 10:43 PM
Chaotic94's Avatar
September 2011 ROTM
You can't get long tubes for a v6. Only mid-length as far as I know
Old 02-11-2011, 11:02 PM
sebi1990's Avatar
My question is if there is even a possibility of getting long tube headers on a v6 and is it possible to buy one part of a system at a time since i don't have enough money to put into the car at once. for a v6 which headers and system would you recommend considering i have a 99 V6 3.8L engine?
Old 02-11-2011, 11:05 PM
sebi1990's Avatar
Which headers would you recommend and long/mid/short-length tube whats is the biggest difference between them except for the amount of fumes they discard from the engine, what are the differences in installation? Which ones are the easiest and hardest to install and why?
Old 02-11-2011, 11:08 PM
BasicConcepts's Avatar
Technical User
i didnt quite make it to headers so i was running stock manis
pacesetter makes a nice header for the price and no there arnt any longtubes for the V6
  #20
Old 02-11-2011, 11:09 PM
Failed Devices's Avatar
The difference between long mid and shorties is the primary tubes lengths (1 promary tube for each cylinder). Only midlength headers are in production for the 3800 iirc, and those are Pacesetters. They run around $250 I believe. A catback will cost around $400 or so for a Magnaflow or Flowmaster.
Quick Reply: Exhaust
