exhaust
Old Apr 13, 2008 | 03:18 PM
jordanreign's Avatar
Default exhaust
I have a 2001 ss and I was wondering if there are any websites that sell an x-pipe. If so when bolting them to long tube headers do you still use the existing cat.
Old Apr 15, 2008 | 01:22 AM
95slvrZ28's Avatar
Default RE: exhaust
If you're looking for an X pipe your best bet is going to be http://www.texas-speed.com/shop/ they have an X pipe that dumps before the rear axels. This is really the only easy way to run true duals, if you still want tips out the back of the car you're going to be paying quite a bit for a Bassani system or a custom setup. As far as Long Tube headers go you have to replace the cats because the collectors come past the stock cat locations. Also if you have to get emissions checked make sure to get headers that have emissions hookups.
Old Apr 15, 2008 | 07:01 PM
libertyforall1776's Avatar
Default RE: exhaust
Or get a tune for emissions to delete the codes...
Old Apr 15, 2008 | 07:19 PM
02StanGT's Avatar
Default RE: exhaust
If you get the sniffer test, tuning out the codes doesn't help you much now does it?
Old Apr 16, 2008 | 02:24 PM
Default RE: exhaust
Depends on the test -- some states have phased out other testing, and only connect to the OBD-II port...
Some states only test in just some of the counties as well...
ORIGINAL: 02StanGT
Old Apr 16, 2008 | 07:05 PM
SpecterGT260's Avatar
Ninja Administrator
Default RE: exhaust
some yes, but out of the states that have it i believe many of them still sniff test. you therefore need to have all of your hookups and cats
Old Apr 16, 2008 | 07:07 PM
02StanGT's Avatar
Default RE: exhaust
ORIGINAL: libertyforall1776
ORIGINAL: 02StanGT
I said sniffer test... I never said it wouldn't work with other tests. READING is fundamental.
Old Apr 22, 2008 | 08:53 PM
cody_3935's Avatar
Default RE: exhaust
i dont blam them for just hookin up the CPU its not good to sniff exhaut fumes
scottlt194
May 14, 2009 08:27 PM
famlyguy18
May 6, 2009 05:26 PM
dbess23
Sep 17, 2007 02:02 AM
javione
Feb 16, 2007 02:27 AM
jhop16
Jan 9, 2007 11:21 AM
