LOUD POP CAN NOISE
Old Apr 6, 2008 | 08:09 PM
DUB C's Avatar
Default LOUD POP CAN NOISE
Well i just got my 97 Z28 out for the first time this year. after i let her warm up a little bit and idle for awhile i took it out for a spin. then all of a sudden i hear a noise coming from the front of the car, sounds like a pop can getting crushed over and over. I was mad and scared what the hell is this noise. well i took it to a friends house that work on cars. he jacks up the car and sees a lot a dimples in the cover for the torque converter. he took it off and there was a small black bolt in there pinging around in there. have no idea where it came from. no work was done on the car, the bolt was not broke but was banged up pretty good. How or where would this come from. thanks for your help.
Old Apr 7, 2008 | 07:50 PM
DUB C's Avatar
Default RE: LOUD POP CAN NOISE
COME ON YOU GUYS YOU ARE CAMARO EXPERTS. ANY IDEA - LOOKS LIKE A OIL PAN BOLT ABOUT THAT SIZE. IT IS BLACK AND DOES NOT HAVE A BIG HEAD. PEOPLE HAVE TOLD HE TRANNY, OIL PAN, FLY WHEEL. HAS ANY ONE ELSE HAD THIS PROBLEM. THE BOLT WAS IN THE INSPECTION COVER FOR THE TORQUE CONVERTER. THANKS AGAIN.
Old Apr 22, 2008 | 07:27 PM
DUB C's Avatar
WELL I CAN SEE I DIDN'T GET ANY HELP. COULD SOMEONE AT LEAST POINT ME TO FIND A DIAGRAM FOR MY CAR THANKS AGAIN.....
Old Apr 22, 2008 | 07:42 PM
SpecterGT260's Avatar
Ninja Administrator
the best you can do is look in the immediate area of the torque converter for a lost bolt. there are only so many ways into a verter. if all seems well there is a good chance it is not the stock verter, but prehaps a rebuilt or OEM one and the bolt found its way in there just due to bad packaging or install.
the problem is very odd, i personally have not heard of this happening before.
i realize its frustrating to not get any responses, but with weird problems like this with no clear cut answer not many members will want to post advice not knowing 100% what the source of the problem even is. however please dont shout.
Old Apr 22, 2008 | 08:03 PM
DUB C's Avatar
I WASN'T SHOUTING - I JUST WAS LOOKING FOR SOME HELP. THANK YOU.. IT'S JUST THATI BOUGHT THE CAR WITH 40,000 MILES ON IT 30TH ANNIVERSARY AND I THOUGHT IT WAS WEIRD ALSO. YOU KNOW I WAS A LITTLE SCARED. LIKE OH CRAP WHAT HAPPENED
Old Apr 22, 2008 | 08:17 PM
Ninja Administrator
i was actually saying, please dont type in all caps . its a little frustrating to read some times. thanks
Old Apr 22, 2008 | 09:27 PM
DUB C's Avatar
Hey after some research on the web could it be a rear main seal bolt. it looks like that alot http://shbox.com/1/rear_main.jpg
could it have come from here
Old Apr 22, 2008 | 09:40 PM
Ninja Administrator
you may want to just drop the whole tranny and make sure everything is in order
Salsa89
10
Aug 15, 2012 08:02 PM
iEchO
Oct 1, 2011 09:02 AM
LeadFarmer
LS Series Tech
Aug 31, 2009 04:59 PM
Saint27
Dec 31, 2007 08:22 PM
Als95Z28
Mar 25, 2006 09:01 PM
