Engine Swap
Old Nov 2, 2007 | 12:20 AM
camaro1207's Avatar
Default Engine Swap
ok, so i have a 1999 camaro v6 5speed. this coming summer im planning on taking the engine out and putting a carburated 383 stroker in it. (yea i know..yall probably thinking its dumb, but its just a project for me). anyways i was wondering bout motor mounts because im pretty sure ima have to do sum modification. what would be the best way to do this so the 383 will have sumthin to hold onto?
Old Nov 2, 2007 | 06:29 AM
97rsturbocamaro's Avatar
Default RE: Engine Swap
actually if you us a LT1 and change it to a crabd. motor and use the motor mounts from that everything should bolt up just fine, you will still have to get a like a 18 curcit wirehardness for headlights and what ever else tho, i put a 460 big block in my crown vic and i had to do the same thing...work out great tho...then i sold it lol...but yeah it will would but id go with an LT1 crab it, then use those motor mounts...i was thinking bout crab. my v8 but im a techie goorooh and rather say with the FI plus it looks cooler lol....
Old Nov 2, 2007 | 06:41 PM
Think of where the distributor is going to fit if you are going to use a regular small block.
3800_seriesII
Aug 14, 2012 07:24 AM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
cachaco736
Dec 11, 2007 11:12 AM
uradumass5695
Oct 21, 2006 08:27 AM
illumastar
Oct 20, 2006 01:42 PM
