Engine acting weird?
Old 02-23-2013, 12:20 AM
NSKY's Avatar
the plugs are less than 5000 miles old. and yea whoosh sorta noise and hot smell. but the smell only after a long drive.
Old 02-23-2013, 12:52 AM
be a good idea to at least test the exhaust to see if the cat or muffler is plugged. cat can plug and go to pieces then plug the muffler. dont need to drill if you have 02 sensors on both sides. just take one out
Old 02-23-2013, 01:20 AM
NSKY's Avatar
Um i dont have a cat. Guy who had it before me removed it. Just found that out.
Old 02-23-2013, 06:55 AM
better test anyways, if muffler is plugged it will do same thing as plugged cat.
Old 03-04-2013, 10:47 PM
NSKY's Avatar
Found the problem. The number 3 wire from coil pack to spark plug was burnt in half. Could only see it after the car was on a lift.
Old 03-05-2013, 06:59 AM
lol,,, thatll cause a misfire. good deal. cheap fix.
Old 03-07-2013, 08:13 AM
Plan on replacing that coil in the next few months. When an 80,000 Volt coil needs to fire and can’t it tends to get very hot. The spark will leak out of the coil. This leakage will cause carbon tracking. The coil will remember that leakage and it will start following that carbon path instead of the plug wire. It is just a matter of time.
Old 03-08-2013, 08:31 AM
NSKY's Avatar
Replaced pack and wire
EagleRex
08-16-2010 02:07 PM
95camaro95
07-06-2010 01:05 PM
Ofallah
06-12-2010 11:46 PM
liltonz609
05-18-2010 06:45 PM
rokinv6
LS Series Tech
02-28-2010 10:52 PM
Quick Reply: Engine acting weird?
