engine for a 94 camaro
Old Sep 17, 2009 | 11:31 PM
roadrunner38864's Avatar
Default engine for a 94 camaro
wat engine is best for a 94 camaro i want to drop a 350 in it but have had people tell me that the 305's are much better.
Old Sep 17, 2009 | 11:38 PM
liaa777's Avatar
are you talking about a z28 that already has a v8 or a six cylinder car? if you go through many past threads people generally agree it is cheaper to buy a v8 car rather then fabricate a sixer engine compartment to house a v8. if your car is already a v8 then the only motor that will really drop right in is an lt1 with the same pcm as the 94 shell you have (providing you have the pcm)
Old Sep 18, 2009 | 12:51 PM
The people that tell you that a 305 is better than a 350 are smoking some really bad weed. As mentioned above, the LT1 would be the a much better fit than a regular 350, mainly because of the limited space between the 350 distributor and the windshield.
Mony Montana
Jan 10, 2013 03:04 PM
ThisGuy68
Jun 20, 2010 02:39 PM
solei
Jun 13, 2009 08:06 PM
guest7
Oct 6, 2008 09:19 PM
zerokool91
May 24, 2008 07:21 AM
