Electrical Smoke?
Old Sep 29, 2009 | 07:00 AM
Rigit's Avatar
Default Electrical Smoke?
1994 V6 Camaro
This has happened to me twice in the past month. I have stopped to get gas. Go to crank it up and it barely turns over (sounds like battery is dead), then starts to smoke like crazy under the hood. I wait a few minutes, try again and it is still slow, but starts up. Smoke appears to come from the left side, maybe under the fuse panel. I really can't tell.
So what do you guys think? Loose wire? I'm scared the old car is gonna burn up.
Old Sep 29, 2009 | 07:26 AM
osduck5's Avatar
Originally Posted by Rigit
1994 V6 Camaro
Need to check for loose wires, fuses, etc. Could be loose connections iin the fuse box arching and melting the box. Need to take a look at it pretty quick or it could be a big fire. Also, check to make sure that the battery connections are clean and tight on both ends.
Old Sep 29, 2009 | 10:32 AM
Check for any corroded wire or component connections in the suspect area. A bad/intermittent connection can cause smoke. In the mean time, it wouldn't hurt to carry a fire extinguisher or marshmallows with you till you get it sorted out. Carbeque's aren't very much fun!
Old Sep 29, 2009 | 10:48 AM
there are ground wires that hook to the block on the front driver side. check them out for any heat damage.
Mesosneaky
Jun 9, 2009 03:03 PM
xeet2050
82-92 V8 Tech
Sep 3, 2008 08:39 PM
3.4CamaroCDOG
Mar 16, 2008 03:13 PM
frostlime69
Nov 29, 2007 09:08 PM
94Z28interceptor
Nov 29, 2006 01:29 AM
