EGR Codes With Brand New EGR Vavle
Ok so I took off the EGR valve and started the car. It didn't try to die but it was stumbling around a bit. No black stuff came from the EGR hole either. Also I just noticed this noise. Any ideas??? It's the rattle when the car gets almost back down to idle. Listen carefully and you'll hear it. Sounds like metal on metal. Maybe a heat shield?
What is this rattling noise ??? - YouTube
Oh buddy check this out. I replaced my fuel filter like 6 months ago and would have never thought it was clogged. I just took it off and guess what? I dumped the fuel out of it and it was black and mucky. Hopefully an easy fix fixes my problem! On my way to oreillys to get a new filter! Wish me luck!!!
Was the inside of your tank clean 6 months ago? Shouldn't be black and mucky now if it was clean.
Hopefully somebody didn't prank you and dump something into your tank.
#20
get that in a diesel tank when the fuel bugs die. so you took the fuel filter out and not the pump or replaced the fuel pump and filter 6 mo ago and just took the filter out
