Downstream O2 Used Upstream?
Old Nov 17, 2020 | 11:06 AM
libertyforall1776's Avatar
Question Downstream O2 Used Upstream?
On an '02 Camaro 3.8L, can I use a downstream O2 sensor in the upstream position? Is there any real differences between them and if so, what are the negatives?
Old Nov 17, 2020 | 05:24 PM
HenryC's Avatar
I'm pretty sure that it matters, at least on newer cars the one after the cat is a wideband o2 sensor and the one before the cat is a narrowband. I believe that on the f body's they used wideband and narrowband.
Old Nov 17, 2020 | 05:26 PM
HenryC's Avatar
If you do use a narrowband o2 sensor downstream then your I/M readiness for your o2 sensors and your cats wont set, your car also may not run right and you'll have a CEL.
camaroteen82
Dec 24, 2013 04:10 AM
aslopez1986
Mar 24, 2011 01:03 PM
pimpdd101
Sep 29, 2008 04:32 PM
Z2896
Jul 22, 2008 11:33 PM
z28pete
Sep 13, 2006 06:50 PM
