Dip stick oil level
Old Nov 24, 2010 | 06:35 PM
Mustang_Eater's Avatar
Default Dip stick oil level
Just noticed that my oil dip stick is about almost half a inch above the grated area where your oil level is supposed to be. Is this too much, will it cause the foam oil problem?
Old Nov 24, 2010 | 07:18 PM
Forgot to mention its a 1998 z28 ls1
Old Nov 24, 2010 | 08:24 PM
Just doing some research on the internet and thought I would add that the engine was not at running temp when I checked this. It had been sitting for a hour and it was pretty cold outside.
I will check again tommorow after the engine is heated up.
Old Nov 24, 2010 | 08:31 PM
woh,,, do you always talk to yourself? lol. yep and you gave good advice to. check oil after shutting it off and see what it reads.
Old Nov 24, 2010 | 09:35 PM
^ ...But not right after shutting it off, as oil will still be clinging to internal parts. Let it settle for a couple of minutes.
Jason Dukes
Mar 14, 2015 01:11 PM
Terry
Dec 31, 2012 07:28 AM
Juggger
Oct 20, 2012 09:39 AM
gearheadLT1
Sep 4, 2009 08:26 AM
CamaroX69
67-69 V8 Tech
Jun 24, 2008 10:36 PM
