Dash lights just stopped working?
Im gonna make this one short and sweet..
I have an 02' Camaro RS or v6 model.
Ive was driving the other day and noticed my speedometer and RPM gauge's are not lighting up. Everything else works, like ASR off, gas light, check engine light... ext. so i cant see how fast im going at night...
What could be causing this?
Please any info on this will be greatly appreciated.
thanks
thanks
so you can see the fuel level in the dark but not the speedo? if so its a bulb or two. may be a good time to look at leds. if they are all out and you cant see anything did you fiddle with the wheel switch for the dash lights to see if they would come on? check fuse. are there any other weird things goin on, if so could be bcm. there is a fix for that.
shinwolf14
09-29-2010 12:39 AM
