cams?
Old Jun 13, 2012 | 04:30 PM
enigma54139's Avatar
Question cams?
can someone please explain cams to me? like what are the difference between all of them. also; is this cam shaft is good? or any recommendations?
3800 V6 - NA Cam
Old Jun 13, 2012 | 04:33 PM
Old Jun 13, 2012 | 04:51 PM
Failed Devices's Avatar
A camshaft is responsible for working the valves for each cylinder. The 3800 has two valves per cylinder, one intake valve and one exhaust valve. The lobes on the cam open and close these valves as the camshaft rotates. Things such as lift, duration and LSA are all important to understand when looking at camshafts. I could try and spell everything out, but this guide is well written and is pretty much what you need to know: *** Cam Guide *** - LS1TECH
However, do take note that a cam swap is quite intensive and expensive if you want to do it right. Just buying a cam by itself is a mistake, you need all the supporting mods for it as well as a proper tune, one done on a dyno most preferably.
Old Jun 13, 2012 | 04:55 PM
here is a neat animation to show the difference in a stock and performance cam.
test popup window
bobc04
May 6, 2009 01:22 AM
94camarokid10
Jan 28, 2009 09:14 PM
FearThisInc
Oct 10, 2008 04:31 AM
Camaroslpss
LS Series Tech
10
Sep 17, 2007 06:43 PM
Camaroslpss
LS Series Tech
Jul 30, 2007 09:14 AM
