Dash lights not working
Old Aug 11, 2008 | 05:23 PM
th3po1son's Avatar
Default Dash lights not working
I have no idea why, they just stopped. I was replacing my gauge cluster lights with LEDs... and they were working, I switched them off, switched them on again, and now they dont work. The fuse is'nt blown either.
Help, please????
Old Aug 11, 2008 | 06:05 PM
02StanGT's Avatar
Default RE: Dash lights not working
Is it just the lights you replaced that aren't working? Or are the lights that come on 'pre-startup' not working either? Gauges work?
Old Aug 11, 2008 | 06:13 PM
th3po1son's Avatar
Yup the gauges work, and so do the warning lights and light indicators (turn signal and high beam). It's acting liek it does when the IP/dimmer fuse is out. Cause I had to replace that fuse once, and its doing the same thing it did when it was out.
Old Aug 11, 2008 | 06:28 PM
noz's Avatar
noz
check for grounds disconnected
Old Aug 11, 2008 | 06:29 PM
02StanGT's Avatar
Is the dimmer set as bright as it will get w/o turning on the interior light? I know my LEDs are either on or off. They don't seem to want to dim.
Old Aug 11, 2008 | 06:42 PM
th3po1son's Avatar
i love you
lmao that fixed it.
and yeah they dont dim they just cut off
Old Aug 11, 2008 | 07:18 PM
02StanGT's Avatar
Good to hear. It sucks when stuff doesn't work right after you just messed with it.
Old Aug 11, 2008 | 09:37 PM
th3po1son's Avatar
Yeah, its all good now
I did the dash lights and the HVAC control lights
looks good cept i have no clue on how to do the light switch.
93-96 interiors are so wierd
Old Aug 11, 2008 | 09:48 PM
th3po1son's Avatar
never mind i just did haha
Old Aug 12, 2008 | 10:51 AM
02StanGT's Avatar
What color did you go with?
