DAMN IT. Coolant hose popped off and intake sucked coolant in.
#21
im guessing blown head, if your pouring coolant and it seems endless and never fills, your coolant is making its way in between the head, into whats called a water jacket, unless its going on the ground which I doubt because you have not mentioned it was leaking on the ground
#22
It isnt going to the ground at all. Does this also mix with the oil? Also, why does my intake spit white gunk out? My intake sucked a lot of coolant in and it smokes like crazy out of the intake. What can I do about that?
#23
Try a new filter and see if that solves any of the smoke
#25
Your Coolant is leaking into the lower end, into the crank, mixing with your oil, hence when you start the car, pressure is sucking the oil/water in to the piston chambers thus pushing it back into the intake out of the TBI base. Wild guess but sounds logical at least
