Couple LT1 questions: knock sensor, spark plug change, 93-96 bose system differences
Old Jun 27, 2015 | 01:26 PM
  #31
ztwentyate's Avatar
oh i saw it.. it was just a matter of me not interpreting the directions properly. and the directions are good.. in hindsight lol.. but during the process i did basically everything wrong. for example, i filled it with the bleeders closed initially. figuring ok once its full.. then i open them. lol wrong. then the bottom of the right side hose blew off and i lost all the coolant. then the coolant level indicator broke and blew some of the coolant out. so mistake after mistake and i finally got it and shes running great! just did an oil change and swapped the wiper arms from a 2002 onto the 93 and got new blades. pretty pleased. if it wasnt like 100 degrees outside and if i had slept at all last night, i might be out there doing a bit more. then again if i didnt work on her last night i might still be struggling with the bleeding process. ill know better for next time!
all the frustration and all the stress and all the **** that goes wrong when you try to fix one thing and something else breaks.. its all worth it once you tie up all the loose ends and really and truly fix what is broken. its a good feeling
stan1277
Sep 7, 2010 08:20 AM
jackrabbit66
Nov 18, 2008 01:13 AM
pimpdd101
Oct 2, 2008 10:16 AM
jofishr
Aug 27, 2006 05:40 AM
CHEVY GUY Z28
82-92 V8 Tech
Jun 20, 2005 12:53 PM
