Coolant Light
Old Nov 9, 2012 | 09:12 PM
JakeYeah's Avatar
Default Coolant Light
Hey whats goin on yall, got a new problem for you guys. My story is this: Driving to work yesterday, service engine soon light comes on. I get out the scanner at my shop and its throwin out low coolant. Thats fine and all, and home today to fill it up. Turns out previous owner just had water in there, and it was kinda murky and had some gunk in it. I flushed the entire system, got rid of the murkiness and gunkiness, filled it a little to much though. A lot more than the fill line says, but not a crazy amount. Go to turn own the old girl, the actual coolant light comes on.. anyone know what this could be?
Old Nov 9, 2012 | 09:26 PM
what did you flush, radiator or the coolant reservoir? need to make sure radiator is full if it is the sensor is most likely failing. what motor?
Old Nov 9, 2012 | 09:43 PM
JakeYeah's Avatar
Radiator might not be full.. LT1 though.
Old Nov 9, 2012 | 09:53 PM
JakeYeah's Avatar
Just went out and topped off the radiator, coolant light when right off. Dont know what happened there, i know im smarter than that. You the man craby.
Old Nov 9, 2012 | 11:20 PM
you will also need to blead the air out of the cooling system. look here https://camaroforums.com/forum/lt1-l...-system-66742/ it is found here https://camaroforums.com/forum/93-02...rt-here-38462/ can also find good info here 4th Gen LT1 F-Body Tech Aids
Old Nov 10, 2012 | 06:20 AM
torque_is_good's Avatar
SES light because of the low coolant sensor?????????????????????????????????????
Old Nov 10, 2012 | 05:15 PM
jkeaton's Avatar
^ yeah, that. You will probably have that light come back on several times until the air is completely gone. I bled mine umpteen million times and still the light would come back on every now and then until the air was completely gone.
bill2129
Jul 24, 2011 10:42 AM
xXChipXx
Oct 25, 2010 01:05 PM
evilbeef54
Jul 27, 2008 09:47 PM
stud1502
Sep 17, 2007 04:54 PM
Z28man
Oct 6, 2006 09:41 PM
