Coolant Leak!! NEED Advice!
Old Dec 10, 2015 | 04:58 AM
Wwjdrfriend's Avatar
Default Coolant Leak!! NEED Advice!
Got a 95 Camaro with 3.4L! Just below thermostat is a thread adapter that has a push in coolant tube with 3 ports coming off tube. One to heater core on the end amd the 2 other are smaller ports that go up to the throttle body. My question is, to remove the tube it looks like a quiche disconnect of sorts. How hard is it to change amd does the tube get destroyed trying to disconnect. I then I found the fitting at O'Riley's but wanted some input before I tore up something and can't find parts! Thanks y'all!
Old Dec 11, 2015 | 09:48 AM
95 camaro 406's Avatar
think you need to post a picture so the guys can help I don't know anything about the 3.4l ,but if you give more info ,an post pics then someone help you
Old Dec 11, 2015 | 11:01 AM
yes thats a quick connect and its called a heater inlet pipe. part #10189204
sohcnick
Mar 25, 2013 04:03 PM
Camaro3800V6
Aug 17, 2011 03:47 PM
TheWifes02Camaro
Jun 25, 2011 08:19 PM
AnalyzeFaith
Dec 5, 2010 05:54 PM
mac022705
Aug 27, 2010 09:28 AM
