constant squeek
Old Apr 10, 2008 | 09:11 PM
baseballer91's Avatar
Default RE: constant squeek
freakin loud as hell
Old Apr 10, 2008 | 09:30 PM
Z28 Kid's Avatar
idk if its it but my 95z had a squealing from under the hood and it was the barring in the AC pullie that i had to change it hasnt squealed since.
Old Apr 10, 2008 | 09:43 PM
meteoralp45's Avatar
well he said, that when he puts wd40 on his belt it goes away
Old Apr 10, 2008 | 09:46 PM
Z28 Kid's Avatar
idk do u think the wd40 might lubricate the pullie temporarily or something making the noise to stop?
95slvrZ28's Avatar
WD-40 isn't the greatest lube of all time, maybe try some belt cream or whatever they make specifically for car belts.
Old Apr 11, 2008 | 01:52 PM
Clod_Z28's Avatar
I had the same problem with my carwith a belt that was only 3 months old, I sprayed it with WD-40 and it just got worse. I drove down to the parts store and bought a new one for a few bucks and I haven't had any problems since. Even though it's fairly new maybe you have a bad belt, I did. The worse that could happen by trying this is that you'll have an extra belt layin around for the future.
Old Apr 11, 2008 | 07:21 PM
Don't spray belts with lube, it just makes matters worse. Take the belt off, spin all the acessories by hand,and check them for binding. If they all seem OK, replace the belt and the tensioner.
Old Apr 11, 2008 | 11:23 PM
I suggest taking the belt off and cleaning it (both sides) and all the pulleys thoroughly with brake cleaner. And I wouldn't put wd-40 on the belt either. Under normal conditions you shouldn't need any kind of belt dressing. Did you ever spill anti-freeze on the belt? That alone can make a belt squeal like a *****, and oiling it up ain't gonna get it out, it will only mask it temporarily.You could also have a worn idler pulley, or another pulley out of whack causing the belt to track out of alignment, which could cause a squeal as it rides too far to one side of the pulley.
PCweber
May 21, 2012 12:25 PM
c4maro
Jan 21, 2011 05:10 PM
3rdgen1986
Oct 3, 2009 05:38 PM
ncbaby72
Jan 9, 2009 04:09 PM
airgasim
May 24, 2007 01:57 AM
