AC blows cold and constant run at idle, cycles on highway
Old May 19, 2012 | 12:23 PM
PCweber's Avatar
Default AC blows cold and constant run at idle, cycles on highway
It blows constant 42 degrees at idle, never cycles. I drive on highway the comressor kicks off after 2 miles for about 10 seconds, then back on. Acts like high side cut off. I always assumed with more airflow (highway speeds) the high side presure goes down so I cant see how the high side could be kicking it out. But how can you tell as I cant have gauged hooked up on highway....
Old May 21, 2012 | 12:25 PM
DashingDaryl's Avatar
I agree that it is probably the high side kicking off your a/c. The faster your engine goes, the faster the compressor goes. Easy solution though. Google a R134 ambeient temperature chart and remove some 134 until you reach the proper pressure.
ChevyManCam
Jan 1, 2011 11:55 AM
Za33cK
May 15, 2009 01:54 PM
shakespearesdad
Dec 1, 2008 06:09 PM
jeez
Nov 22, 2005 06:37 PM
HotRod53
Apr 29, 2005 09:46 AM
