checking codes on 94 Z28 (OBD I)
Old Dec 19, 2007 | 05:33 AM
jbassiii's Avatar
Default checking codes on 94 Z28 (OBD I)
I plug in the tool, switch the key to "on", the electric fan comes on, the "Check gages" light comes on, but the check engine light doesn't flash any codes, not even 12
(the check engine light does flash during startup)
Old Dec 19, 2007 | 01:09 PM
1994z28's Avatar
Default RE: checking codes on 94 Z28 (OBD I)
You cant flash the codes out by jumping the A and B terminals on the 94. You have to use a obd1 scantool to retrieve the codes.
Old Dec 19, 2007 | 03:43 PM
Nobody listens....
Old Dec 19, 2007 | 04:25 PM
Spartan66's Avatar
Im pretty sure my check engine light flashes before i turn the ignition on.. or maybe thats check guages.. or even my security light... but i have no codes..
Old Dec 19, 2007 | 05:09 PM
LT1RUNNER's Avatar
Pete's correct! He's posted some good info on this subject( read below). Go to the COMPUTER topic and you'll see everything you need there!! Even I posted something and it was already there in my face. Here you go!
You cannot flash the codes on 94 and 95 camaros. The 94 can be scanned with an OBD1 scanner, but most code readers will not work. For the 95 car GM got a little weird and you need an OBD1 scanner with a OBD2 style cable or you can make your own adapter. See the FAQ on top of this section.
https://camaroforums.com/m_128940/tm.htm
< Message edited by z28pete -- 12/9/2007 5:28:39 PM >
_____________________________
Pete
SeaBass1944
Mar 7, 2015 08:19 AM
Mr. Hollywood
May 26, 2009 10:29 PM
djquik1
Mar 29, 2008 09:26 AM
kclark
Jul 12, 2006 05:25 AM
