check engine light
Old 03-28-2013, 11:30 AM
What the heck? The unrelated responses (pin jumping) started out harmless, but it turned out to be it's own side conversation totally unrelated to what the OP can do with his 94. It may have been helpful to someone somewhere else, but not to this guy. That's what Gorn was trying to fix, to avoid jumping off the subject to something unrelated. What went on was a prime example of a thread hijack. You guys take a little correction way too seriously, and personally.
Old 03-28-2013, 01:08 PM
afronippleyo's Avatar
Isnt 96 obd2 and 94 obd1? unless you replaced/modified the wiring harness and ECM, you would have issues... at least I'd think you would...
Old 03-28-2013, 07:15 PM
assuming its a lt1, engines are the same, sensors are the same, nope should not have issue, unless he changed the ecm.
EagleRex
05-29-2010 04:48 PM
ghanahost
02-21-2010 12:49 PM
Chevykicksbut
10-28-2009 07:14 AM
gozzy341
05-20-2007 11:00 AM
teamlilE1
03-12-2006 02:22 AM
Quick Reply: check engine light
