changing shocks running into one problem after another-help!
Old Jun 19, 2011 | 02:26 PM
auto's Avatar
Default changing shocks running into one problem after another-help!
so i pulled the shock out (passenger side front) and the strut mount was rusted so bad i could see or feel the nut so i grinded it off and eventually got the mount off, my question is what parts do i re use because i cant get the metal cap underneath the boot off now
Old Jun 19, 2011 | 09:14 PM
libertyforall1776's Avatar
Shock Mount, 4th Gens have no struts. What metal cap do you mean -- the cap that is part of the dust-boot cover? Post pictures so we can see what you mean. Which shocks are you upgrading to?
Old Jun 20, 2011 | 09:46 AM
auto's Avatar
im going from stock to the bilsteins from stranos
Old Jun 20, 2011 | 10:12 AM
Do what you can to get that cap & dust boot off your old shock without destroying them since they're discontinued parts. Saw off the top of the old shock or remove that bulb of junk stopping it. The cap connects to the dustboot. Once you do that, get a rubber mallet and whack off the spring mount for reuse. Might want to clean them up then hit them with some semigloss or gloss antirust spray before putting them on the new shock.
Old Jun 20, 2011 | 10:24 AM
auto's Avatar
theres a flange keeping that metal cap in place, not the rubber gunk
Old Jun 20, 2011 | 11:38 AM
Nope, no flange, that is the metal sleeve which broke out of your shock mount, which means you need a new mount too. Cut it off of cut between the cap and the dustboot..
Old Jun 20, 2011 | 12:10 PM
auto's Avatar
okay i see what you were talking about, just want to get it right the first time so starting from the bottom it goes..
lower spring holder,spring seat,bump stop, metal cap,boot, spring, strut mount?
Old Jun 20, 2011 | 12:16 PM
^ Exactly, except it's a shock mount.
Use a thin layer of anti-seaze lube on the upper shock thread, so it doesn't rust and fuse in the future... Be certain you torque that upper shock nut on properly with the springs compressed enough, else you will be redoing this job...
Old Jun 20, 2011 | 12:37 PM
auto's Avatar
how much torque is enough? i always just tighten till it cant go anymore, then give it a 1/4 turn
Old Jun 20, 2011 | 04:06 PM
I couldn't get my torque wrench in there due to size, but if you have one that fits, you torque it to spec.
