Changin AUTOMATIC TRANSMISSION
Old Jan 19, 2008 | 11:36 PM
chevy_man's Avatar
Default Changin AUTOMATIC TRANSMISSION
HEY GUYS I GOT A 98 TRANS AM AND IM GETTING BORED OF THE AUTO TRANSMISSION!! [:-]I WANT TO CHANGE IT TO 6 SPEED BUT I KNOW THATS A HELL OF A LOT OF HEADACHES!! WHAT WOULD IT TAKE EXACTLY TO DO THAT?? BUT YEA im just wondering what i can do to make my auto transmission a lil "funner" something thats more aggresive but still good for an everyday driver...LET ME KNOW...THANKS
Old Jan 19, 2008 | 11:46 PM
The Banks's Avatar
Default RE: Changin AUTOMATIC TRANSMISSION
Parts list from a sticky on LS1tech.
master + slave cylinders (prefer 01 up) (also, master cylinder u-bolt and nuts)
new pedal assembly with clips for clutch rod and brake rod
new console tray with shift boot, and lower shift boot
pilot bearing, bellhousing, T56, crossmember, T56 torque arm mount and bolts, shifter
pressure plate, flywheel, clutch, and all related bolts and clutch tool
You will need to have your PCM flashed to a 6spd PCM, but you do not need a new PCM
Some good info here:
http://ls1tech.com/forums/showthread.php?t=200480
Edit:My bad, hopefully this is more helpful.
Old Jan 20, 2008 | 12:01 AM
chevy_man's Avatar
do you kno what else you would have to change cuz that sounds to easy haha cuz i got a cousin that can get the tranny no problem but man i thought it would be a lot more modifications than that...??...
Old Jan 20, 2008 | 12:34 AM
The Banks's Avatar
I fixed my previous post for ya. Supposably GM High Tech did an auto to manual conversion and did a write up, that would probably be a good resource if you're gonna do it yourself.
Old Jan 20, 2008 | 07:26 AM
JD1969's Avatar
It's not a big deal, I went the other way man-auto and it was pretty easy. I think you should get a big stall converter for your auto and smoke people who think autos are slow.
Old Jan 20, 2008 | 09:22 AM
Chappie99's Avatar
You will need a lot of experience and paitence. Along with $$$ and the proper tools. A lift would be helpful and lots of beer and good music. An occasional stripper to stop by to take your mind off things would really soften the blow. (Pardon the pun.)
Old Jan 21, 2008 | 10:50 AM
JD1969's Avatar
ORIGINAL: Chappie99
Spoken like a person who has never done the swap. The hardest part will be getting the car to a tuner to get the ECM re-tuned.
Old Jan 21, 2008 | 04:13 PM
95slvrZ28's Avatar
Try to find the GM tech article about it...after you read that try to decide if you still want to go through with it.
JD, it's good to see you around with your "slow" auto again Where have you been man!?
Ash05
May 28, 2014 04:23 PM
Hyde_GT
Oct 15, 2006 11:30 AM
firebirdmonkey
Aug 9, 2006 07:18 AM
JaySan
Jun 23, 2006 01:29 AM
