cat delete
I never smelt gas it will help if you have done something on the intake side. If your car is like my 95 before they started putting o2sensors after the cats you won't have a service light. If you do you may want to put a high flow cat or simulators on, so your car doesn't run in loop mode.
Hello, I recently tried the catless route and my car got alot louder and was pretty stinky. I got a Magnaflow high flow cat replacement for less than 100$ on ebay. It was a weld in job so it was time consuming but the car sounds good and doesn't stink (my car is a convertible) plus I think these engines run better with alittle back pressure. Good luck and shop around alittle.
