Car won't start! Daily driver! Help!!!
Old May 17, 2012 | 09:33 PM
well if he cleaned the map it may be toast, i dont think your supposed to spray stuff in them. still if it is the map i think it will run with it unplugged.
Old May 17, 2012 | 09:42 PM
jonescamaros's Avatar
Originally Posted by craby
yes and when you turn the pressure down the extra gas goes through the system, lots of it with a high volume pump, even more with a motor that burns very little fuel. im not saying it wont work, if the fuel pressure regulator fits it should work. im sayin its overkill, maybe to the point of causing the pump or fuel pressure regulator to fail sooner rather than later.
OHHH! That makes sense! I wasn't arguing, just trying to learn as much as I can! Thanks for your help!
Old May 18, 2012 | 02:57 PM
I just did what the directions on the can said to do...
mike6208
Apr 14, 2012 05:10 AM
flamingpyro12345
Aug 21, 2008 08:23 PM
