car problems
Old Jul 13, 2011 | 09:42 PM
3800camaro's Avatar
That's good to know. Guess I'll swap my PCM and try to figure out the speed difference until i get my new rear end in. I'll try the PCM swap and see if the codes come back.
Old Jul 13, 2011 | 10:03 PM
if the pcm is tuned the tune my have went wack.
Old Jul 13, 2011 | 11:14 PM
3800camaro's Avatar
Its still the stock PCM in it right now. Been waiting for a few parts before i put my tuned PCM in.
Old Jul 15, 2011 | 07:16 PM
3800camaro's Avatar
ok so i have tried replacing the pcm and the problems were still the same. the only code i keep getting is the ect sensor code so i'm going to replace that tonight or tomorrow afternoon. i'm also going to replace the t-stat. I also pulled my #1 + #2 spark plug and they are both just covered in carbon with a huge gap so those are being replaced as well. the wires are still good. Hopefully doing this well help the no start problem and the insane random idle. If it still wont start i'll look into the fuel system and check pressures and maybe pull the injectors.
Old Jul 15, 2011 | 07:17 PM
3800camaro's Avatar
Also what is the recommended spark plug gap? is it 0.060?
Old Jul 16, 2011 | 05:31 PM
3800camaro's Avatar
ok so i replaced my ect sensor and now it purrs like a kitten. i decided to regap my plugs instead. i also left my t-stat alone since it looked good. got a spare just incase i ever need to do a quick change.
Old Jul 16, 2011 | 06:42 PM
kool. if your plugs are fouled (black) it would be a good idea to replace them.
Old Jul 16, 2011 | 07:45 PM
3800camaro's Avatar
It was only the 2 front plugs that were black. The others were fine. This winter I'll change them when I hopefully pull the engine to rebuild it.
mp734
Nov 6, 2013 11:54 AM
nmallory56
Jul 21, 2009 03:34 PM
IZZY1967RS
Jun 19, 2008 10:29 PM
jdubs1813
Nov 12, 2007 04:16 PM
Nov 11, 2007 11:56 AM
